Tris Cocks Posted October 8, 2010 Share Posted October 8, 2010 I need to service my swivels over the weekend as there is play between 12 and 6, reading the manual it says that i need to use a spring balance to get the resistance measuring between 1.46 and 1.6kg after getting over the initial resistance, The problem is that i havent got a spring balance, is there another way of setting swivel up withough using a spring balance? Cheers Tris Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 8, 2010 Share Posted October 8, 2010 I ended up buying a balance from ebay for a couple of quid and just did it as per manual. I suspect if you did a lot of them you could probably do it by feel. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 8, 2010 Share Posted October 8, 2010 I bought a spring balance from my local hardware shop. it was a silverline one, and about £3?? or something like that. I agree Aragorn, If you were doing lots on a regular basis you'd be able to do them by feel. Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2010 Share Posted October 8, 2010 I need to service my swivels over the weekend as there is play between 12 and 6, reading the manual it says that i need to use a spring balance to get the resistance measuring between 1.46 and 1.6kg after getting over the initial resistance, The problem is that i havent got a spring balance, is there another way of setting swivel up withough using a spring balance? Cheers Tris get one from a fishing eqiupment shop, there's one in cross street, camborne, if you can't find one locally to you. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted October 8, 2010 Share Posted October 8, 2010 I've used a weight on a string over a pulley before now, it has the advantage of not needing to read the scale on someting that is moving. Later Railko types could be set when new using a torque wrench and an adapter. Quote Link to comment Share on other sites More sharing options...
