renault4 Posted October 14, 2010 Share Posted October 14, 2010 I am in the middle of re-building my front hubs and swivels, now in the archives Les says that the haynes and rave torque values are wrong, instead of the published 58ft.lbs. he says it should be 17ft.lbs. (quite a big difference) well my Land Rover workshop manual quotes 58ft.lbs. so which figure is right? Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 14, 2010 Share Posted October 14, 2010 The way i read Les article, I think the top pin bolts are 58ft.lbs, but the bottom is 17. Arent the lower bolts smaller than the upper ones so it kinda makes sense? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 14, 2010 Share Posted October 14, 2010 bottom ones are M8, you'll snap them trying to do them up to 58lbft! Top ones should be 58. Quote Link to comment Share on other sites More sharing options...
renault4 Posted October 15, 2010 Author Share Posted October 15, 2010 Les deffinatly refers to the top bolts when he says "17ft. lbs. not 58ft.lbs." Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 15, 2010 Share Posted October 15, 2010 Pm Les - that'll clear it up. I still think you can read it both ways. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 15, 2010 Share Posted October 15, 2010 I posted about it when i did mine: http://forums.lr4x4.com/index.php?showtopic=55281 Quote Link to comment Share on other sites More sharing options...
renault4 Posted October 15, 2010 Author Share Posted October 15, 2010 well thanks to Mo Murphy and his magic chart, I think I may have cleared up this mystery. the bolts on the upper pin are 10mm (17mm spanner) and the grade stamped on the top of the bolt is 10.9 and the corresponding value for this bolt is 47ft.lbs. exactly what dear old Haynes says. maybe where Les got his figures from is that tere are two types of upper pin depending on the year of the land rover and I think the newer ones have smaller bolts. it just goes to show you should never take anything for granted, always double check. thanks guys for all the replys. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 15, 2010 Share Posted October 15, 2010 Always wise to double check, certainly better than breaking a bolt Don't be too hard on Uncle Les, he's just old Mo Quote Link to comment Share on other sites More sharing options...
renault4 Posted October 15, 2010 Author Share Posted October 15, 2010 sorry, should have thanked Les first of all, THANKS LES. Quote Link to comment Share on other sites More sharing options...
