Rear tub floor replacement
So I've been advised that instead of buying the actual part (MTC8184) for the floor, that I should really get some aluminium cut to size and some struts.
I have ordered the cross members for this, and would like peoples opinions and (pretty please?) pictures!
Can anybody give me accurate dimensions of the floor section that I need to get cut? (I'd measure it but it's miles away!!)
Early90, thank you so much for posting those pictures- must be a few thousand words worth!
I will measure my own truck on saturday. What kind of thing do you need to do the rivets? Any of the cheaper ones from machine mart good enough? (http://www.machinemart.co.uk/shop/search/filter/rivet/type/any/page/1)
Time to get in contact with YRM!
Get the best riviting tool you can afford,i used machine screws and rivnuts around the edges...it is all obvious when you get the old floor out....good luck. More info here.... http://www.landroveraddict.com/smf/index.php?topic=372300.msg516638#msg516638
