dannyboi Posted October 22, 2010 Share Posted October 22, 2010 hi all i would like to put a straight through exhaust on my 90 2.5td and have the tail pipe out of the passenger side rear quater just behind the door but the question i have is, will the power still be the same with all the boxes removed or will this just cause it to be slugish and have no power ? any help would be apreciated thanks dan Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 22, 2010 Share Posted October 22, 2010 Without the silencers in there it will be better should rev more freely Quote Link to comment Share on other sites More sharing options...
dannyboi Posted October 22, 2010 Author Share Posted October 22, 2010 sounds good then il start geting that sorted Quote Link to comment Share on other sites More sharing options...
berti1554 Posted October 23, 2010 Share Posted October 23, 2010 Be careful with overreving the turbo as there is no backpressure. You may will see some peaks in revs... Quote Link to comment Share on other sites More sharing options...
landypc Posted October 23, 2010 Share Posted October 23, 2010 Hi, T304 stainless de-cat pipe and a straight through system. All available from good sources, 5Alive, IRB, B.A.S etc. Give them a call or look up on the web. Easy to find. All are worth talking to and will advise if you are going OTT. Good luck landypc Quote Link to comment Share on other sites More sharing options...
jbs Posted October 24, 2010 Share Posted October 24, 2010 I have a straight through exhaust on my 200 tdi 90 it does make it more responsive and also rev's more freely too, it also seems a little more powerful and a lot more noisy but I like it John Quote Link to comment Share on other sites More sharing options...
dannyboi Posted October 24, 2010 Author Share Posted October 24, 2010 ok thanks for the help guys Quote Link to comment Share on other sites More sharing options...
slomofo Posted October 26, 2010 Share Posted October 26, 2010 I put the straight through centre section on my 200tdi Def90( removes x2 Silencers) I honestly can't tell if there is any improvement in response/power - but it does sound a little more potent. Backbox off and a side exit through rear wing 1/4 methinks.... Quote Link to comment Share on other sites More sharing options...
