robhybrid Posted November 2, 2010 Share Posted November 2, 2010 I am running a Izusu coupled up to a v8 auto box, I have got a chance of a dead 300tdi auto box.(a clutch gone? no forward gears) mate of mine has just bought a relatively good condition disco to have the engine out of it. would I benifit anything from chopping and changing components between the 2? I am looking at using the end vehicle on the road over winter -next 6 months ish. Is the stall speed on the 300 tdi torque converter different? to v8 Is the auto box Governor different is it interchangeable? my v8 one sometimes sticks in 1st before changing up. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 2, 2010 Share Posted November 2, 2010 If your V8 one sticks in first sometimes it is on it's way out, you may get 100 miles or 20,000 miles, but something isn't working as it should.... re-reading Ashcroft's site they site it as being the governor needing cleaning or replacing, though it sounds like you probably already know this.... an oil and filter change and governor clean may well fix it, but you are taking a chance. The 300TDi box is definitely different with change points more suited to the diesels power band, the V8 would work as is, but not be ideal. The torque converter for the diesel box is smaller than the V8 IIRC too. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted November 4, 2010 Share Posted November 4, 2010 I believe the v8 spec autobox is far better suited to the power curve of the isuzu, i have an ashcroft recon v8 auto behind an isuzu in my hybrid and the power delivery and gear shift is very good, compared to a the 300auto it seems loads better, i've always found that 300auto's are very slow to takeup drive and feel missmatched on gear ratios and selection. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 6, 2010 Share Posted November 6, 2010 Kickdown on a V8 box can take you up to 5,000rpm. I'm not sure how well that would go down on the Isuzu but on a LR TDi I wouldn't say it's adviseable. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 6, 2010 Share Posted November 6, 2010 Kickdown at motorway speeds is "interesting" with a V8 box behind a 300Tdi, certainly, but otherwise I find mine works quite well. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 8, 2010 Share Posted November 8, 2010 No kidding. I don't know if my gearbox has been tweaked yet (it needs a rebuild though)but flat out on the motorway it goes well past the speed limit in 2nd. My sister has a 300TDi auto (factory) and it revs to pst 4,000 rpm on kickdown but nowhere near as fast as the V8. Quote Link to comment Share on other sites More sharing options...
