SteveG Posted June 14, 2006 Share Posted June 14, 2006 Picked up this of ebay to replace my centre section that I keep knocking off road.. What gaskets and any sealant do I need to fit it? I assume they are standard exhaust gaskets. Thanks Steve Quote Link to comment Share on other sites More sharing options...
JST Posted June 14, 2006 Share Posted June 14, 2006 i fitted mine using the exisitng gaskets no problems, i suggest 6(?) new nuts and bolts mine were corroded on but then your is newer so should be less problems. i didnt use any sealant. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 14, 2006 Share Posted June 14, 2006 Didn't think the exhausts had gaskets? If you want some sealant then Holts Firegum is a good one to use Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 14, 2006 Share Posted June 14, 2006 You might need a cone-shaped collar to connect sections and to get a gas tight seal. It depends on the ends of the exhaust, which aren't clear in your picture. Standard L/R collars are quite wide and add about an inch at either end to the length of the system. Looks a bit messy too, so when I made the system for catflap I used Jaguar ones, which are solid and thinner - while still fitting the profile of the pipe ends that I had fitted. The reason being that the added length was only a few mm, and the whole thing looked a lot tidier. Take the pipe to any exhaust place and they will match up a suitable sealing collar for you. Fire gum or gun gum are both excellent exhaust sealants - the former for new, close seals, and the latter for larger gaps. If you are going to use the pipe joint to change direction of the exhaust, rather than putting a bend in the pipe - the jaguar ones are not suitable for this as they leave little room for pipe deviation at the joint. Les. Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 16, 2006 Author Share Posted June 16, 2006 thanks for the replies guys. Cheers Steve Quote Link to comment Share on other sites More sharing options...
