RRC 3.9 no spark ??
jamesvfr
Hi all
Range rover 3.9 on a j plate
picked it up cheap as a non runner
After cranking it over for a while i can smell a hint of fuel from the tail pipe which sort of says to me that there is fuel getting in but just no spark
Checked spark at the plug but nothing then put ht lead coming from the coil v close to earth but nothing
It already has a new coil + new plugs, whats the best sequence to be checking + trouble shooting?
Cheers
James
  • 2 weeks later...
Bit of good news, its alive
Theres power at the coil when ignition on but power dissapears when switch is in cranking position so i run a wire from battery positive to coil just to get it to fire, now just got to see why
Cheers for the help
James
Without looking at the wiring diagram, you may have a blown fuse somewhere... first place to check I would say.
After that, then ignition switch, see if you get power on the ignition live wire out of it when in position 3.
