Jimmy Two-Jacks Posted November 18, 2010 Share Posted November 18, 2010 I have replaced my rather tatty 1986 90's instrument pod/panel with another from a scrap yard and all seems ok however the speedometer reads 20mph without even being connected yet I have turned the drive manually with a small stick and the needle spins freely and will go to zero if you rotate the stick that way but flicks back to 20mph??? Is this right or is it knackered? Or does the speedo drive keep it at 0 ish when fitted? Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2010 Share Posted November 18, 2010 it's busted, the speedo should rest at 0 when the vehicle is parked or stationary in traffic. now you could upgrade to the Td5 speedo & forget evr changing a speedo cabe again. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted November 18, 2010 Author Share Posted November 18, 2010 I have replaced my rather tatty 1986 90's instrument pod/panel with another from a scrap yard and all seems ok however the speedometer reads 20mph without even being connected yet I have turned the drive manually with a small stick and the needle spins freely and will go to zero if you rotate the stick that way but flicks back to 20mph??? Is this right or is it knackered? Or does the speedo drive keep it at 0 ish when fitted? Oh well never mind....Thanks for the info as ever. Cheers James Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2010 Share Posted November 18, 2010 even with the speedo removed the needle should be at rest at 0 mph same with cable disconnected from speedo or transferbox. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 18, 2010 Share Posted November 18, 2010 You can have my old one... that always sticks at zero... even when moving Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted November 20, 2010 Author Share Posted November 20, 2010 Update: I thought that was that £35 down the crouk without a poodle having bought it online from a breakers in Manchester (Broadbent autos) thinking that it would a be waste of time to contact them to tell them it didn’t work . Anyway I decided to drop them an email...Well they couldn’t have been nicer they replied promptly and are sending me another in the post on Monday without any fuss or aggravation. So I can recommend their services fully and such nice folks . Quote Link to comment Share on other sites More sharing options...
western Posted November 20, 2010 Share Posted November 20, 2010 good to read of good customer service, well done to Broadbent autos Quote Link to comment Share on other sites More sharing options...
