Mack Posted November 21, 2010 Share Posted November 21, 2010 Hi guys I´m looking for aftermarket bearings: STC3185 FRC5564 STC1130 (I read somewhere here it is SKF 6207, but there are meny 6270 ones) thanks in advance. M Quote Link to comment Share on other sites More sharing options...
western Posted November 21, 2010 Share Posted November 21, 2010 STC3185 -- Timken NP027538 FRC5564 STC1130 SKF 6207 not a LR part number.see above bearing. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted November 21, 2010 Share Posted November 21, 2010 The mainshaft bearings that Ashcrofts supplied with my new crossdrilled gear are Fersa 18790/20 if that helps - this is a 20D box. Looking at one of the old cups it is Timken 18720 - I can't check the cone number because I left both cones on the old gear The bearings on the intermediate shaft were Timken X33205 (cone) / Y33205 (cup). I don't know if they were factory originals or replacements. New boxed sets are labelled 33205-92KA1. The bit of the Timken catalog that I have shows NP027538 as a cone with the same bore/width (25mm/22mm) with a note that "NP parts are made for specific applications". I didn't replace the output shaft (ball) bearings so I don't know those sorry. I do have the F+R diff carrier numbers if you need those. I have found Ashcrofts to be very helpful Quote Link to comment Share on other sites More sharing options...
Mack Posted November 21, 2010 Author Share Posted November 21, 2010 Top guys. Thanks Quote Link to comment Share on other sites More sharing options...
Mack Posted November 26, 2010 Author Share Posted November 26, 2010 back again. I got lucky and found all bearings for the Tbox. The NP027538 seem to be equivalent to (fersa or skf 33205) Now, I´m after STC1156 and STC2808 (inner and outer P38 type rear diff). have not found them in the web (yet). Any hints? thanks, M Quote Link to comment Share on other sites More sharing options...
western Posted November 26, 2010 Share Posted November 26, 2010 back again. I got lucky and found all bearings for the Tbox. The NP027538 seem to be equivalent to (fersa or skf 33205) Now, I´m after STC1156 and STC2808 (inner and outer P38 type rear diff). have not found them in the web (yet). Any hints? thanks, M STC1156 more ;links here STC2808 more links here Quote Link to comment Share on other sites More sharing options...
Mack Posted November 26, 2010 Author Share Posted November 26, 2010 I´ve seen those. I´m after Timken, SKF, Koyo, etc. Got STC1156 as JXC25743C/D thanks M Quote Link to comment Share on other sites More sharing options...
western Posted November 26, 2010 Share Posted November 26, 2010 these Timken catologue links might help. http://www.timken.com/en-us/products/Pages/Catalogs.aspx Quote Link to comment Share on other sites More sharing options...
Mack Posted November 26, 2010 Author Share Posted November 26, 2010 How did skip that one! Anyway Rover P38 type bearings seem to be: Cone/Cup (Inner) HM801346X-HM801310 Cone/Cup (Outer) M88046-M88010 Quote Link to comment Share on other sites More sharing options...
Mack Posted September 17, 2011 Author Share Posted September 17, 2011 Above is wrong: Pinion bearings are: JXC25743C/ JXC25743D inner bearing NP850232/JXC10238DF outer bearing Quote Link to comment Share on other sites More sharing options...
