oggie27_3 Posted November 29, 2010 Share Posted November 29, 2010 hi, as per the title i am after the domed nuts and captive bolts for a td5 D2 after mine sheared today whilst changing the battery. thanks in advance. jon. Quote Link to comment Share on other sites More sharing options...
western Posted November 29, 2010 Share Posted November 29, 2010 only battery fixing nuts in my microcat for a Td5 D2 are flanged nut M6 part FN106047L, with either J bolts AMR5280 or straight bolts AMR5735 Quote Link to comment Share on other sites More sharing options...
oggie27_3 Posted November 30, 2010 Author Share Posted November 30, 2010 Sorry western I should have been more specific. I an after the terminal nut and captive bolt. Not the actual battery securing clamp. Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2010 Share Posted November 30, 2010 Sorry western I should have been more specific. I an after the terminal nut and captive bolt. Not the actual battery securing clamp. ah, that helps, microcat only shows the battery cables as a assembly, it doesn't list the bolt/nut as seperate parts. any suitable sized bolt/nut will do as a replacement. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted November 30, 2010 Share Posted November 30, 2010 Sorry western I should have been more specific. I an after the terminal nut and captive bolt. Not the actual battery securing clamp. As Ralph has said, in the post above, they're not available separately, you have to buy complete new positive and negative battery leads, at great expense IMO, the type of battery clamps Land Rover use are cr@p A heavy-handed gorilla of a previous owner had over-tightened the ones on mine and they were no longer able to clamp the battery posts tight enough. I cut the connectors off of the ends of the battery cables and crimped on tube terminals with a 10mm hole, I can't remember if I used 25mm2 or 35mm2 terminals (there's about a foot of snow on my car at the moment, so I'm not going outside to have a look ) - and used these on the battery posts - Positive & Negative battery connector with 10mm stud - . . Quote Link to comment Share on other sites More sharing options...
oggie27_3 Posted November 30, 2010 Author Share Posted November 30, 2010 thanks for that guys. much appriciated. best get some new terminals then! Quote Link to comment Share on other sites More sharing options...
