jagwit Posted November 30, 2010 Share Posted November 30, 2010 I have a 2004 South African specification 4.0 Disco 2 V8. This low compression engine runs open loop (it does not have Lambda sensors). I have now installed a Rover high compression 4.6 in its place. So far it seems happy with the fuel and timing it gets. Presumably the fuel map just sees more air being used and supplies more fuel and the knock sensors are keeping detonation under control. Can not help but wonder if there is not a more optimal fuel and timing map available developed for the 4.6. I understand that US Disco 2s came with 4.6. 1) If so, are they (running on the same fuel and timing maps as my car? 2) How does the ECU know when to use the lambda sensors and when not to? All input will be appreciated. Quote Link to comment Share on other sites More sharing options...
pinhead Posted December 2, 2010 Share Posted December 2, 2010 If anyone knows about this I am very interested also as I fancy a striker crank for mine when it is rebuild time Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 2, 2010 Share Posted December 2, 2010 Simple answer - convert to Megasquirt and you can set it all up as you want it. Quote Link to comment Share on other sites More sharing options...
jagwit Posted December 2, 2010 Author Share Posted December 2, 2010 Simple answer - convert to Megasquirt and you can set it all up as you want it. Have you done MS on a Thor using the oem crank sensor? Quote Link to comment Share on other sites More sharing options...
pegasus Posted December 2, 2010 Share Posted December 2, 2010 Hi The fuel map for a 4.0 engine and a 4.6 are slightly diffrent, but both maps are held in the ecu. This can be altered through test book, not sure if it can be done through nanocom or hawkeye , but i would have thought so. Mark Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 2, 2010 Share Posted December 2, 2010 Have you done MS on a Thor using the oem crank sensor? No, because the crank trigger pattern is not compatible with EDIS. It's very doable with direct coil drive from the ECU, but that is a faff - it's more robust to stick a 36-1 trigger wheel on the crank pulley and run EDIS. Quote Link to comment Share on other sites More sharing options...
