stuck Posted December 21, 2010 Share Posted December 21, 2010 Gents, With a good snorkel and raised breathers how fit for wading is a standard 110 TD5? My RR had Megasquirt, never had a TD5 or indeed a Diesel before, nervous about taking the plunge without prior information. Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 21, 2010 Share Posted December 21, 2010 I don't have a TD5 but from what I understand, you have a computerthingamychipmabob in your engine. It's probably best to relocate that to the roof of your cab. oh, and expect your feet to get wet too also I have read a lot about making sure your snorkel is properly sealed otherwise it is just a waste of time. Maybe someone can throw some more light on this.... Quote Link to comment Share on other sites More sharing options...
stuck Posted December 21, 2010 Author Share Posted December 21, 2010 Bloody hell that was a quick reply! I'm used to getting my feet wet, just don't like walking home Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted December 22, 2010 Share Posted December 22, 2010 As posted above....your ecu is under the drivers seat and is NOT water proof....there are a few companys selling the harness extension leads so you can relocate the ecu much higher up....there is also a couple of relays in there too so they need to be put in a sealed box or moved higher....dont forget your fuse box above the gearbox tunnel. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 22, 2010 Share Posted December 22, 2010 You also need to be wary of the fly by wire throttle I think. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 22, 2010 Share Posted December 22, 2010 Throttle is an issue, ECU is under the seat. Having seen the price of TD5 loom extensions, I'd buy some wire and get the soldering iron out, they're insane money. Quote Link to comment Share on other sites More sharing options...
stuck Posted December 22, 2010 Author Share Posted December 22, 2010 Thanks Gents. Wondering if TD5 was such a good idea, nah I'm not. Quote Link to comment Share on other sites More sharing options...
