5122 Posted January 13, 2011 Share Posted January 13, 2011 Hello, I've broken the plastic T-junction (several litres of washer liquid up my sleeve ) located under the lower plastic guard of the front bumper (splitting the hose to the left and right washer jet). RAVE doesn't show it, neither does my workshop manual. Would really like a part number for this little bugger please Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 13, 2011 Share Posted January 13, 2011 Hydraulics / pneumatics suppliers should be able to sort you out with something sturdier for not much, a nice bit 'o brass perhaps. Failing that, you may be able to bodge it with garden hose bits from B&Q etc. Quote Link to comment Share on other sites More sharing options...
5122 Posted January 13, 2011 Author Share Posted January 13, 2011 You are right, haven't thought about that. So fixed on proper parts and numbers! Thanks Quote Link to comment Share on other sites More sharing options...
M&S Posted January 13, 2011 Share Posted January 13, 2011 I went to "motorworld" or whatever they are called now, they sell all of those types of fittiongs for 99p a pack, t's, elbows, straights etc. They are a bit tight but fit fine if you warm the pipe up in boiling water first Quote Link to comment Share on other sites More sharing options...
5122 Posted January 13, 2011 Author Share Posted January 13, 2011 Good stuff, thanks for the tip! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 13, 2011 Share Posted January 13, 2011 Or any aquarium shop will have what you need. Ask for a t-piece for an airline. The airline tubing is the same size as the washer jet tubes, in fact my 88" uses aquarium airline tubing bits throughout, the tube, non-return valve and t-piece Quote Link to comment Share on other sites More sharing options...
5122 Posted January 17, 2011 Author Share Posted January 17, 2011 Ah, thanks for the aquatic tip! Good stuff! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 17, 2011 Share Posted January 17, 2011 The aquatic tip may not work for headlamp washers, the hose is much bigger bore (about 10mm / 1/2" from memory) whereas most B&Q / aquatic stuff is 6mm. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 17, 2011 Share Posted January 17, 2011 Aquatic airline tubing is 6mm OD / 4mm ID, so if the headlamp washers are 10mm (~3/8") or 1/2" then that won't work no. However, most aquatics stores should stock T-pieces in those sizes too, I know mine does anyhow. A lot of water features use either 3/8" or 1/2" hose. Quote Link to comment Share on other sites More sharing options...
