cabell Posted January 18, 2011 Share Posted January 18, 2011 I have an early 110 base model that came with no interior trim except visors. I have added a headlining, td5 bulkhead matting , and 200tdi tunnel cover. Now I'm onto the seatbox. I've seen carpet and a very thin vinyl material with a super thin foam backing. The vinyl thing looks like it would have little or no sound deadening qualities. Is there anything available for an lt77 seatbox that will deaden sound? I'm aware of the Wright Offroad kits, but as I have everything else covered I really just need the seatbox bit. The genuine td5 stuff for the r380 box is great and I am wondering if there is anything similar for the lt.Mine is lhd if anyone has any part numbers handy. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 19, 2011 Share Posted January 19, 2011 Other than the Wright Off Road stuff and carpet there isn't anything for the LT77. If you really do want something then you're going to have to modify a TD5 seatbox cover. HTH Mo Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 19, 2011 Share Posted January 19, 2011 Have you tried contacting Wright Off Road? They might supply just the panel(s) required. Quote Link to comment Share on other sites More sharing options...
cabell Posted January 19, 2011 Author Share Posted January 19, 2011 Thanks guys. I'll contact Wright to see if I can purchase just the seatbox cover. Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2011 Share Posted January 19, 2011 have a look through here from page 924 onwards shows the sound proofing/insulation for all LT77 or R380 gearbox fitted 110's. Quote Link to comment Share on other sites More sharing options...
cabell Posted January 19, 2011 Author Share Posted January 19, 2011 have a look through here from page 924 onwards shows the sound proofing/insulation for all LT77 or R380 gearbox fitted 110's. Thanks very much Western. Can you tell me where the vin # break is between the lt77 and the 380? Quote Link to comment Share on other sites More sharing options...
western Posted January 20, 2011 Share Posted January 20, 2011 R380 only came factory fitted with the 300tdi engines, the bit that fits on top of the seatbox is the same AFAIK, seatbox top hasn't changed much. if the chassis number has a 10th digit that is a 'L' it will be a very late 200tdi with a LT77 or 'M' it's a 300Tdi/R380. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 20, 2011 Share Posted January 20, 2011 The R380 mat is the wrong shape around the gearbox tunnel on the front of the seatbox. The cutout for the handbrake is consequently in the wrong place also. HTH Mo Quote Link to comment Share on other sites More sharing options...
