thefarrier Posted February 12, 2011 Share Posted February 12, 2011 i came across a 24 spline kam air locker (that right air locker) which i didnt even know they had made, works a lot like new type but has a box half way down the axle and has a air operated fork the slides a shaft on or off the flange that locks the diff, just wondered if any one on here has one or tried one so i can fine out if its worth ago Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 12, 2011 Share Posted February 12, 2011 Thats not a new one - thats a very old one! The main problem with them is the lack of spare parts for them as KAM havnt made this model for many years. Jon Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 12, 2011 Share Posted February 12, 2011 About 18 if I recall correctly Nige Quote Link to comment Share on other sites More sharing options...
simonr Posted February 13, 2011 Share Posted February 13, 2011 However, if you know the right people, getting new shafts or internal components made isn't that hard. PM me if you need bits and I'll put you in touch with the appropriate companies. You can get a custom shaft made for under £100 in pretty much any material you like. Si Quote Link to comment Share on other sites More sharing options...
Rizla 1 Posted February 13, 2011 Share Posted February 13, 2011 We used this type many many year ago and after nearly every trial under the car fixing it the trouble with them is shaft twist - then the sliding dog don't slide and jams some say they have got better now ? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 13, 2011 Share Posted February 13, 2011 As you say the early KAM diffs have a hugely long spline where the lock unit slides up and down, the mildest twists sees this "Jam up", and there is not much you can do about it, The new system used std type shafts, so you can use any shaft from std to m300+unobtanium etc - whatever your fancy, the locker works via a dog lock system, so no long splines. The new shafts are far superior in both Metal spec, and treatments, they are in my humble up there with the best they did do some super long shafts for the old system,so you could "Upgrade" but the prices of the shafts are such I wouldn't do it, better to sell the working system, and use the money for other options. I have 2 x ARBs in my truck, but have the KAM Halfshafts and CV units, I have not heard of any issues with breakages on these new shafts, quite the reverse In the curent challenge world the old system just is not man enough, ghowever 20 years ago when it was made it ticked the boxes things have moved on at an amazing rate and also whats out there to buy Bit like saying I have an early 8074 and was thinking of going gigglepin twin motor, prob not the best value for money route Nige Quote Link to comment Share on other sites More sharing options...
simonr Posted February 14, 2011 Share Posted February 14, 2011 As you say the early KAM diffs have a hugely long spline where the lock unit slides up and down, the mildest twists sees this "Jam up", and there is not much you can do about it, Err - actually there is! The internal splines on the bit that slides over the half-shaft are fairly long. If you use a lathe to reduce the length of the female spline - it jams less for a given twist. The splines are longer than they need to be to transmit the torque. Si Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 14, 2011 Share Posted February 14, 2011 Fair point Si But then you iz a very clever sod Nige Quote Link to comment Share on other sites More sharing options...
thefarrier Posted February 16, 2011 Author Share Posted February 16, 2011 i am going to go arb instead but if any one wants this set up with diff and axle case for not much money let me know and they can have it told bloke i got it off and he said sell it. let me know Quote Link to comment Share on other sites More sharing options...
