Tibout Posted February 26, 2011 Share Posted February 26, 2011 hi just got another landy it's a 110 300tdi. had it for like 3 weeks and the last 2 weeks the abs will start kicking at very slow speed specially when turning. i lost all the brakes yesterday had to pull the hand brake to stop. but it seems that the abs was kicking but it make such a grinding noise as if wheel bearing is gone. i've done the pads 2 weeks ago notice no play in wheel bearing. the things is that i don't know if the abs light is suppose to come on when atarting the vehicle and then turn off when reaching about 5mph! the landy never did that. any clues guys. any help more that wellcome. thierry Quote Link to comment Share on other sites More sharing options...
101sean Posted February 26, 2011 Share Posted February 26, 2011 Yes, if have ABS the dash light should come on when you start the engine and go out when you get to 5mph or so unless there's a fault and it will stay on. It's possible a PO has disabled the light to disguise the problem? Quote Link to comment Share on other sites More sharing options...
Tibout Posted February 26, 2011 Author Share Posted February 26, 2011 hi the lights never comes on. whats a PO? i have the instruction of doing the dianogsis but if the light is not on it could mean that the ecu won't find any issues!!! and if it find the fault how to clear the fault after fixing the problem? thanks a mil Quote Link to comment Share on other sites More sharing options...
western Posted February 26, 2011 Share Posted February 26, 2011 whats a PO? Previous Owner Quote Link to comment Share on other sites More sharing options...
Tibout Posted February 26, 2011 Author Share Posted February 26, 2011 thanks western Quote Link to comment Share on other sites More sharing options...
