subseauk Posted February 28, 2011 Share Posted February 28, 2011 Morning all Trying to find the LR Part numbers for the two types of swivel seals used on chrome balls. I have been told there are a thick and a thin type of same seal. Dealer looked at me as if i was mad!! Cheers Kev Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2011 Share Posted February 28, 2011 only 1 seal far as I know. FTC3401 [9mm] for Defender 90/110/130. front & rear disc brakes page 415 item 11 for 110 vehicles with front disc & rear drum brakes.refer to axle number notes below part number list Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 28, 2011 Share Posted February 28, 2011 Ralphy Poohs Swivels seal, not hub Early RR vs Later Lrs I thought ? Its the depth of the seal, the OD and ID are the same ? Nige Quote Link to comment Share on other sites More sharing options...
subseauk Posted February 28, 2011 Author Share Posted February 28, 2011 As far as we can tell Ralph the 90 has had a RR 1978-1985 rear axle with a 10 sline diff fitted for discs and the front axle looks quite old as it has much thicker hub driving members than found on newer type axles. IMHO this must have been a much stronger unit than current thinner ones! Maybe LR were trying to shave material costs at some stage?? I had already purchased the FTC3401 ( 9mm) from the local dealer as these were the only type he knew about!! Fingers crossed i don't open her up and find different!!! Best Rgds Kev Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2011 Share Posted February 28, 2011 Ralphy Poohs Swivels seal, not hub Early RR vs Later Lrs I thought ? Its the depth of the seal, the OD and ID are the same ? Nige should have read as 415 not 451 now amended to read correctly. Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2011 Share Posted February 28, 2011 As far as we can tell Ralph the 90 has had a RR 1978-1985 rear axle with a 10 sline diff fitted for discs and the front axle looks quite old as it has much thicker hub driving members than found on newer type axles. IMHO this must have been a much stronger unit than current thinner ones! Maybe LR were trying to shave material costs at some stage?? I had already purchased the FTC3401 ( 9mm) from the local dealer as these were the only type he knew about!! Fingers crossed i don't open her up and find different!!! Best Rgds Kev 90/110 used thicker drive flanges [driving members] on pre Tdi vehicle.so front axle is most likely a original to that 90, my 110 is a '89 & I've got FTC3401 swivel seals fitted. it's the only number now. other in the link has been superseded. Quote Link to comment Share on other sites More sharing options...
subseauk Posted February 28, 2011 Author Share Posted February 28, 2011 90/110 used thicker drive flanges [driving members] on pre Tdi vehicle.so front axle is most likely a original to that 90, my 110 is a '89 & I've got FTC3401 swivel seals fitted. it's the only number now. other in the link has been superseded. Guys This is the only place i've found that lists a 12.5mm swivel housing seal but it is for early discovery .....could this be what you're thinking of Nige? http://www.landroverspares.co.uk/product.html?id=4340 Other than this i can't find anything else!!! Rgds Kev Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 28, 2011 Share Posted February 28, 2011 Thats the (other) Baby Nige Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2011 Share Posted February 28, 2011 that 12.5mm is on here too http://www.lrseries.com/shop/product/listing/1486/571890-CHROME-SWIVEL-BALL-OIL-SEAL.html?search=571890&page=1 Quote Link to comment Share on other sites More sharing options...
subseauk Posted February 28, 2011 Author Share Posted February 28, 2011 that 12.5mm is on here too http://www.lrseries.com/shop/product/listing/1486/571890-CHROME-SWIVEL-BALL-OIL-SEAL.html?search=571890&page=1 Damn!!! at £26 each plus £7 postage those LR original are an expensive gamble to buy 2 of if they are wrong size Nige!!! I know we should use genuine LR seals but i am tempted to go with the cheaper ones this time around and replace with genuine LR seals next time if need be in case it is the thinner ones we need and these have already been ordered from LR dealer. What are your thoughts? I can order these tomorrow. Rgds Kev Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 1, 2011 Share Posted March 1, 2011 Good Plan Nige Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 1, 2011 Author Share Posted March 1, 2011 Good Plan Nige All parts ordered Nige, New radiator unit here and waiting to be fitted once i get back Hopefully all ready to go for next week subject to a job not cropping up!! Rgds Kev Quote Link to comment Share on other sites More sharing options...
