mudmagnet Posted March 4, 2011 Share Posted March 4, 2011 is it a difficult job to change the auto box filter as my 300tdi has done over 140,000 and looking through the service history it dosnt look like its ever been changed Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted March 4, 2011 Share Posted March 4, 2011 is it a difficult job to change the auto box filter as my 300tdi has done over 140,000 and looking through the service history it dosnt look like its ever been changed Hope someone comes along soon as I want to do this as well John Quote Link to comment Share on other sites More sharing options...
RoaryV8 Posted March 4, 2011 Share Posted March 4, 2011 Dont thinks its that bad of a job, think Cross-member has to be removed to drop the sump but other than that just general undoing etc.... Quote Link to comment Share on other sites More sharing options...
teabag Posted March 5, 2011 Share Posted March 5, 2011 Also on a Tdi a gearbox mount has to be removed to enable access to a sump bolt so it will require a support while the job is being carried out. V8s require the Y pipe and cross member removed. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted March 6, 2011 Share Posted March 6, 2011 Also on a Tdi a gearbox mount has to be removed to enable access to a sump bolt so it will require a support while the job is being carried out. It does? damn hadn't noticed when I weighed the job up. On the V8 the hardest bit is splitting the sports pipe. just be careful with the torque setting on the sump, too easy to strip the bolts. I was tempted to conevrt to studs last time. Also the rubber gasket is a faff to keep in place. Before you do it though have a look at Ashcroft's website regarding changing oil. Often disturbing the oil in a neglected gearbox makes things worse! Quote Link to comment Share on other sites More sharing options...
mudmagnet Posted March 6, 2011 Author Share Posted March 6, 2011 maybe i will just leave it well alone after reading the ashcroft site the oil is clear red so should be ok Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted March 8, 2011 Share Posted March 8, 2011 Lucas oils do an additive to "rejuvenate" old oil. I tried it in my new oil to help protect the gearbox from my big engine. My forst box it worked well, when that whent the second hand box I fitted lasted 180 miles, so I don't think anything would save it. Quote Link to comment Share on other sites More sharing options...
