Bobtail Posted March 4, 2011 Share Posted March 4, 2011 I need some help i have a Factory 200TDI Rangie It has started to miss when driven I have fitted new fuel filter and lift pump I can Rev it cleanly when sat But as soon as you start to drive it at around 2000rpm it will start to miss push it even more and it will cut out as if youve turned the ignition off Please help it doin my head in cheers Jim Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 4, 2011 Share Posted March 4, 2011 Fuel lift pump causing lack of fuel at higher demand ! Quote Link to comment Share on other sites More sharing options...
Bobtail Posted March 4, 2011 Author Share Posted March 4, 2011 New one already fitted and new filter Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 4, 2011 Share Posted March 4, 2011 Didn't come in a blue box did it? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted March 4, 2011 Share Posted March 4, 2011 Have a look at the fuel pipe where it comes out of the top of the tank,they rust through and pull in air. Quote Link to comment Share on other sites More sharing options...
Bobtail Posted March 12, 2011 Author Share Posted March 12, 2011 Well i changed the lift pump and filter still no better A Friend suggested the filter on the bottom of the pick up in the tank So removed sender unit from tank today and there is no filter on the bottom So poked a tie wrap down both tubes and the pick up one had something in it So a little bit of poking with a long spring and hey presto a large lump of black plop fell out Quick clean of the tube with some brake cleaner Refit and test drive and it works Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted March 13, 2011 Share Posted March 13, 2011 well done! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 13, 2011 Share Posted March 13, 2011 So now you're going to fit a filter right? Quote Link to comment Share on other sites More sharing options...
