seth's dad Posted March 11, 2011 Share Posted March 11, 2011 evening all, is it possible to use my power steering pump from my 19j engine and replace it on the 200tdi im putting in. I ask because my steering box is a 6 bolt and this engine has come without any power steering pipe work. If i can just swap the pump over, im thinking that i could use my existing pipe work knowing that the pipe unions are the same. I dont mind extending any pipes but i dont really want the delay in getting some others many thanks in advance Quote Link to comment Share on other sites More sharing options...
crclifford Posted March 11, 2011 Share Posted March 11, 2011 Hi, I don't think you can just swap the pumps over, as if i remember correctly from my conversion, you'd need to make a new bracket as the belt run on a 200tdi is different to that of a TD. That said if you can fabricate the required bracket then you should be ok to use the old pump. Chris Quote Link to comment Share on other sites More sharing options...
western Posted March 11, 2011 Share Posted March 11, 2011 if your TD engine has PAS/Alternator bracket item 2 on page 155 it & the PAS pump part number ETC9070 3rd photo in this thread PAS Pump Clarification then it will fit a 200tdi engine, my Defender spec 200Tdi has this pump fitted. Quote Link to comment Share on other sites More sharing options...
L835 Posted March 12, 2011 Share Posted March 12, 2011 evening all, is it possible to use my power steering pump from my 19j engine and replace it on the 200tdi im putting in. I ask because my steering box is a 6 bolt and this engine has come without any power steering pipe work. If i can just swap the pump over, im thinking that i could use my existing pipe work knowing that the pipe unions are the same. I dont mind extending any pipes but i dont really want the delay in getting some others many thanks in advance Shameless plug but I'm selling a pump, pipes and box from a200tdi on flea bay.... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110658831976&ssPageName=STRK:MESELX:IT#ht_500wt_1156 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110658944514&ssPageName=STRK:MESELX:IT#ht_500wt_1156 Quote Link to comment Share on other sites More sharing options...
