Snagger Posted March 14, 2011 Share Posted March 14, 2011 Hi again. I bought a second hand speedo to send of for recalibration when I do my axle swap. It's in MPH and has the trip meter as well as the odometer, and is definitely a SIII unit (the voltage regulator mountings and "shadow"from where a stabiliser has been fitted are a give-away). The numbers at the bottom of the face don't match those in my 109 (SNT 6209/24 1306), which is surprisingly accurate. Can anyone tell me what this unit is from - my guess is that it is from an 88" with 6.50 tyres, but it might be from a Stage I V8. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 14, 2011 Share Posted March 14, 2011 1503 turns per mile, compared to your 109's 1306. So it's for a vehicle with smaller wheels (ie. more turns required for each mile) that yours if your speedo reads accurate Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 14, 2011 Share Posted March 14, 2011 1504 is for SWB with 6.00 or 6.50 tyres. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14, 2011 Author Share Posted March 14, 2011 Thanks, guys. That's actually quite good news - the Lightweight's speedo was playing up and a new cable didn't fix it. The speedo head is knackered - with the mechanism removed, the needle sticks and seems to have a broken return spring. I'll get it rebuilt at some point as it's the original, showing the correct odometer reading but also in the correct KMH calibration. This second hand unit will do in the mean time (I'd leave it in as it's easier to read the MPH scale, but Helena want it more original), but is showing nearly 20,000 miles too much. I opened it up to clean it up, oil the mechanism and respray the bezel - it looks like new except for the odometer. Quote Link to comment Share on other sites More sharing options...
Swifty oh no Posted March 17, 2011 Share Posted March 17, 2011 If you go here:- http://www.land-rover-lightweight.co.uk/LRL%20Wheels.html Scroll down you will find the calculations for which speedo you should be using with which tyre sizes. Quote Link to comment Share on other sites More sharing options...
