soton rrc Posted March 31, 2011 Share Posted March 31, 2011 Hi, I have a problem with a lack of acceleration on my 1975 RR classic V8 petrol fitted with twin stromberg carbs. Prior the last weekend all seems well, but using it last w/e going up any sort of hill I needed to change down to a lower gear and have little power. The car starts fine from cold (on choke) and appears to run well on idle and ticks over fine. I do very little milage per year (about 600 miles), mainly locally. The spark plugs were changed three years ago along with the air filters, and the carb. diaphragms along with new rotor arm, distributor cap and plug leads were changed 18 months ago. Also, when i start the car from cold using the choke, the engine often only starts with a lack of power until 5 to 10 seconds later when full power kicks in. Are these problems concected ? Any help given is gratfully received, ie what should i be checking first. Also, does anyone have experience of using a good garage in the Southampton area; who are used to dealing with early Range Rover's. Thanks very much Quote Link to comment Share on other sites More sharing options...
stuck Posted March 31, 2011 Share Posted March 31, 2011 Have you had a look at your fuel filter? That's where I would start. Quote Link to comment Share on other sites More sharing options...
Pete The Biker Posted April 1, 2011 Share Posted April 1, 2011 appears to run well on idle and ticks over fine Mine sometimes misfires on one cylinder and its not that obvious, though it causes a loss of power. Might be worth checking out the plugs and leads. Pete Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 1, 2011 Share Posted April 1, 2011 If you have any leaky vacuum pipes, especially the one to the distributor vacuum advance capsule, or if the capsule itself is faulty, that can lead to significant loss of power due to the ignition timing not being where you need it. This is more obvious the harder you work the engine. Checks you can do youself - look for a small bore rubber hose running from between the carbs to the distributor. Check that a) it's connected both ends, b) it's not horribly perished. If these are OK, with engine off, disconnect the pipe at the carb end, and suck on the pipe quite hard and try to hold the vacuum by sticking your tongue over the end of the pipe. If no vac is achieved or maintained, you have a faulty vacuum advance capsule. Quote Link to comment Share on other sites More sharing options...
zoltan Posted April 1, 2011 Share Posted April 1, 2011 I would check the diaphragms in the carbs again Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 1, 2011 Share Posted April 1, 2011 Strombergs IMHO were never that good re performance, compared with SU's, but you have to start at the absolute basics and work through Tinming, advance working fully, plugs GENUINE Leads and cap and Rotor arm, diaphrams in carbs, Float bowls and filters Fuel pump pressure clean pistons with correct grade and amount of damping oil etc etc etc If there is any doubt re the genuine LR Cap Rotor arm and leads start there Nige Quote Link to comment Share on other sites More sharing options...
Escape Posted April 4, 2011 Share Posted April 4, 2011 Depending on mileage, and if the easier checks don't give any results, take off the oilpan and see if the timing chain is still tight. Quote Link to comment Share on other sites More sharing options...
