seth's dad Posted April 3, 2011 Share Posted April 3, 2011 evening all just tried out my 110 after putting a 200tdi in and found a hisssing noise at the engine end by the bulkhead, i can feel gases escaping and the power is down as well, i was wondering if i've missed a breather hose or worse still the head gasket. Any ideas are welcome Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 3, 2011 Share Posted April 3, 2011 hose from Turbo to inlet split or come off ? Quote Link to comment Share on other sites More sharing options...
seth's dad Posted April 3, 2011 Author Share Posted April 3, 2011 I've put new hoses on from the turbo to the inlet manifold and air cleaner, these gases are coming from the top of the head area by the bulkhead unless there's another hose that should be around there Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2011 Share Posted April 3, 2011 exhaust downpipe to turbo outlet exhaust manifold gasket or joint at manifold elbow to centre part blowing head gasket blowing at rear of head Quote Link to comment Share on other sites More sharing options...
voevod Posted April 3, 2011 Share Posted April 3, 2011 I have a similar problem on mine,check the pipe between brake master cylinder and vacuum also check the servo for leaks.Also,did you refit the bolt that holds the dipstick tube to the inlet manifold when you did the swap?I didnt and the power was well down and sounded like I had a tarpaulin stuck in the front axle!...just a couple of other things you can check Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted April 4, 2011 Share Posted April 4, 2011 mine & a [palsh done exacly that & they were both the head gasket that had perished in that area, proberbley get shot down for saying this but all we done was change the gasket on both without skimming the head & mine ran fine for 18 month before I broke it for spares & sold the engine to a guy in Holland & last I heard it was running fine, My pal is still using his everey day without any issues. John Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 4, 2011 Share Posted April 4, 2011 Exhaust leak, head gasket blow at the rear of the head (quite common on the 200TDi engine), do not usually produce a hissing noise. Vaccuum leak will (brake servo circuit) Inlet manifold gasket will make a hissing noise as well. Ans as Lesmund says - turbo/intercooler pipes. Les Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 4, 2011 Share Posted April 4, 2011 Had the head gasket "chuffing" on the back of no 4 cylinder for ages....thought it was the exhaust for ages Quote Link to comment Share on other sites More sharing options...
seth's dad Posted April 4, 2011 Author Share Posted April 4, 2011 Thanks for all the replies, guys. had a quick look in the daylight and i think the head gasket is shot at the back of the head, the missus will be pleased, told her i was doing the decoratin this weekend, after spending so much time on the landy just lately Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 4, 2011 Share Posted April 4, 2011 Put your hand down the back of the head while the engine is running - you'll soon feel if the head gasket is gone. Strange for it to be a hiss though - head gasket usually chuffs Les. Quote Link to comment Share on other sites More sharing options...
