Smokydiesel Posted April 8, 2011 Share Posted April 8, 2011 Hi, Can I use the softtop hoop-set from a 109 on my 88 ?? Obviously with leaving one section out...... Thanks ! Edwin Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 8, 2011 Share Posted April 8, 2011 Yes but the middle hoop and longitudinal bars on the 88" are specific to that model. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted April 9, 2011 Share Posted April 9, 2011 As Phil says - the middle hoop which sits on the side members is used on the 88 3/4 tilt as well - but the side bars are longer with a full hood. The components are available from Exmoor trim and no doubt others as well as the normal spares stockists. You will also need the 2 little rope fittings behind the doors on the tub (fix them very close to the door aperture edge) 2 loop/cleats for the back and 2 strap fittings above the antiluces (use existing rivet holes.) Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted April 9, 2011 Author Share Posted April 9, 2011 Thank you !! Edwin Quote Link to comment Share on other sites More sharing options...
ToyRoverlander Posted April 10, 2011 Share Posted April 10, 2011 You will also need the 2 little rope fittings behind the doors on the tub (fix them very close to the door aperture edge) 2 loop/cleats for the back and 2 strap fittings above the antiluces (use existing rivet holes.) What are those and where exactly do they go? I want to make a 4door softtop so mine doesn't have all the fittings on the tub. I'm trying to work out what I need. So that will be the things you describe above plus 10, I think, of those loops or whatever you call them that fit to the side of the tub, where you hook the rope behind. Correct? Quote Link to comment Share on other sites More sharing options...
