bobzilla7 Posted July 13, 2006 Share Posted July 13, 2006 Does anyone know the best and cheapest place to get glazed door tops? Thanks Quote Link to comment Share on other sites More sharing options...
dasterdly Posted July 13, 2006 Share Posted July 13, 2006 evening, not to sure that best and cheapest go together, but paddocks supply glazed door tops for around £50 each, as do craddocks, i dont think there will be to much differance in price, but a google search may dig up something. cheers... Quote Link to comment Share on other sites More sharing options...
simonb Posted July 13, 2006 Share Posted July 13, 2006 when you get them, remove the window lock catch in the frame and pour in loads of waxoil, tilt the frame so that it runs out at both ends and tilt it sideways so that it coats the side of the bottom channel as well. OR buy the all aluminium ones at twice the price! Quote Link to comment Share on other sites More sharing options...
toomuchlength Posted July 14, 2006 Share Posted July 14, 2006 had problem's with Rocky Mountain doortops not being the right shape (they don't follow the windscreen frame), dunno if this is the same with others but may be worth getting unglazed, bend as required and then glaze Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 15, 2006 Share Posted July 15, 2006 Do you have the old door tops? You can swap the glass over and save yourself a few quid. You can use that plastic channelling as well and not worry about rotting window guides. Les. Quote Link to comment Share on other sites More sharing options...
wookie162 Posted July 15, 2006 Share Posted July 15, 2006 where can u get the plastic channels from lez? Quote Link to comment Share on other sites More sharing options...
bobzilla7 Posted July 15, 2006 Author Share Posted July 15, 2006 had problem's with Rocky Mountain doortops not being the right shape (they don't follow the windscreen frame), dunno if this is the same with others but may be worth getting unglazed, bend as required and then glaze I've reglazed in the past on a different vehicle and never had great results. Quote Link to comment Share on other sites More sharing options...
bobzilla7 Posted July 15, 2006 Author Share Posted July 15, 2006 when you get them, remove the window lock catch in the frame and pour in loads of waxoil, tilt the frame so that it runs out at both ends and tilt it sideways so that it coats the side of the bottom channel as well. OR buy the all aluminium ones at twice the price! Who sells ali ones? That makes sense, even at twice the price! Quote Link to comment Share on other sites More sharing options...
Ivan Posted July 17, 2006 Share Posted July 17, 2006 wookie162 You can get the plastic channel from the Series III club. They will have a stand selling it at Billing. Ivan Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 17, 2006 Share Posted July 17, 2006 I think Bearmach etc also sell the channelling. About a fiver a strip I think. I have the alloy door tops as well - both bits of glass slide. Les. Quote Link to comment Share on other sites More sharing options...
