zim Posted May 5, 2011 Share Posted May 5, 2011 Morning, I've currently got a defender axle with the 46mm piston calipers, solid discs. If i get a set of vented calipers and discs, will it all just bolt up ? Could you confirm that STC1267 and STC1266 have the 46mm pistons ? I'm not at home and need to order spares Thanks Gordon Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 5, 2011 Share Posted May 5, 2011 I wont just bolt up .. You will need to fit caliper spacers, which will involve splittting the calipers in half to fit them and you will require new internal seals Micro- Cat Western will be along soon no doubt to confirm part no's Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted May 5, 2011 Share Posted May 5, 2011 les he is asking if he can bolt vented disks and calipers straight on,to which the answer is yes. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 5, 2011 Share Posted May 5, 2011 That'll teach me for replying to a thread just after I get into work and not reading it properly...... Quote Link to comment Share on other sites More sharing options...
western Posted May 5, 2011 Share Posted May 5, 2011 Morning, I've currently got a defender axle with the 46mm piston calipers, solid discs. If i get a set of vented calipers and discs, will it all just bolt up ? Could you confirm that STC1267 and STC1266 have the 46mm pistons ? I'm not at home and need to order spares Thanks Gordon Caipers for vented front disc will bolt straight on. STC1266 is now SEB500460 STC1267 is now SEB500470 no photo of RHF vented caliper, but this photo of LHF vented caliper Quote Link to comment Share on other sites More sharing options...
zim Posted May 5, 2011 Author Share Posted May 5, 2011 Thanks Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted May 6, 2011 Share Posted May 6, 2011 Yes AFAIK it's 130 front brakes (RRC vented disks) but if the callipers you have are good a clighlty cheaper option is a spacer kit that incliudes all the seals and bolts you need. EBC disks are pretty good too if you need to stop a lot of weight. Quote Link to comment Share on other sites More sharing options...
