Rightfoot Posted May 30, 2011 Share Posted May 30, 2011 I've got to replace the fuel tank as its starting to weep on the seams. Currently the fuel pump is mounted on the outrigger for the fuel tank, the good point is that its low down, but it strikes me that its a bit exposed, even though the bulkhead outrigger gives it some protection. As per the photo: I was wondering whether it was sensible to relocate to the inside of the seat box where it is more protected, but then it is higher up. Is this a good or bad idea?. Also there is no filter anywhere in the system as far as I can see, do I need one? If so before or after the pump (my instinct says before), and any recommendations as to type? Its an ex range Rover 3.5 on carbs. Quote Link to comment Share on other sites More sharing options...
moore101 Posted May 30, 2011 Share Posted May 30, 2011 In tank pump will be furthest out of the way but requires an SD1 sender/pump bracket or another hole cutting in the top of tank. So without doing that I'd be looking for somewhere a little bit more protected like mounting it on the inside of the chassis rail or you could just put a cover over the existing pump as a gaurd. Keeping the existing pump will want it kept low to help it gravity feed as I've got a feeling most pumps don't really like having to lift fuel up to height but will all easily push it along lines. Quote Link to comment Share on other sites More sharing options...
disco2hse Posted May 31, 2011 Share Posted May 31, 2011 On my Stage 1 (3.5 V8, etc.) I have two tanks, one in the rear and one up front under the drivers seat. There are two pumps, one for the side tank is mounted on the inside of the chassis rail just behind the rear most portion of the tank itself. The other, for the rear tank, is mounted immediately behind the side tank on the chassis rail. The two pumps are therefore directly opposite each other on the same chassis rail. So, umm. Take your pick, inside or outside. Both work as well. But yes, they are mounted behind the tank and not in front of it. Admittedly the one on the outside of the rail comes in for a lot flack from the rear tyre. Alan Quote Link to comment Share on other sites More sharing options...
task Posted May 31, 2011 Share Posted May 31, 2011 LWB or SWB? My SWB pump is mounted as follows; Sorry for the massive image size, also ignore the EFi Pump mounted in-tank, that was done when I was building the Series 3 to aid transition to the EFi later on Quote Link to comment Share on other sites More sharing options...
Rightfoot Posted May 31, 2011 Author Share Posted May 31, 2011 SWB - and I was thinking of mounting mine just where yours is as its nice and protected. No supply problems with it being mounted that high? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 31, 2011 Share Posted May 31, 2011 My Facet is mounted under the seat and the tank is in the back (109), it is happy drawing fuel. There is a filter in the end of the facet but it's more to filter out medium sized rocks and trees and small animals than anything meaningful, I'd splash £2.50 and stick an extra filter after the pump. Quote Link to comment Share on other sites More sharing options...
task Posted June 1, 2011 Share Posted June 1, 2011 No supply problems at all Quote Link to comment Share on other sites More sharing options...
