trog Posted May 31, 2011 Share Posted May 31, 2011 Hi all, I`m new to this forum and have an early 94 disco 1. The prob I have is I have a 2" lift on the disco which was on when I bought it 3 years ago. Apart from the usual cost of MOTS and the like its been a great tool. Coming back from Lincoln the other day on the A1, I hit what looked like a half house brick at about 60mph. This resulted in only what I can describe as the worst tank slapper that nearly ended up with my demise. It didn`t seem to be much of a jolt from the offending object but all the same I had to pull up on the hard shoulder for a minute or two before I discided to risk continuing the rest of the journey home. The point is there didn`t seem to bee anything wrong, but I took the journey home the scenic route to be more safe than sorry, and after further investigation could`n`t find what could Have caused the severe wobble. As anyone any ideas of whats wrong or had any similar problems P.S. The suspension seems to be Britpart super-gas shocks and yellow springs. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted May 31, 2011 Share Posted May 31, 2011 now just say if im wrong but isn't a tank slapper a over reaction of the driver?? Quote Link to comment Share on other sites More sharing options...
SPendrey Posted May 31, 2011 Share Posted May 31, 2011 I would imagine simply hitting the brick at that speed is enough?! No doubt you slowed down immediately, but still 60mph to hit something hard and I would also assume a bit of a swerve would be enough. The lift wouldn't have helped, but I don't think it alone would be the cause. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted May 31, 2011 Share Posted May 31, 2011 Oh, and welcome by the way Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted June 1, 2011 Share Posted June 1, 2011 Did you get a wobble through the steering wheel which could only be bought under control by slowing down? This could be bump steer which can be made worse by a lift as the castor on the front axle puts the steering geometry out of wack. This and worn swivel bearings/preload can possibly cause what you are describing. Check your preload on the swivels and that might fix it. If not you may have to fit castor corrected radius arms too. Or just avoid bricks in the road! Quote Link to comment Share on other sites More sharing options...
Niamh Posted June 1, 2011 Share Posted June 1, 2011 Knackered Steering damper? Niamh Quote Link to comment Share on other sites More sharing options...
Biffo Posted June 1, 2011 Share Posted June 1, 2011 All of the above, none of which are expensive to sort out, also check the bushes in the panhard rod. With a 2" lift these are under extra strain especially if it's still the standard rod. Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted June 1, 2011 Share Posted June 1, 2011 Yes from experience I can tell you it is amazing just how much play you can get from worn panhard rod bushes ( and they dont even have to appear worn) Hugh Quote Link to comment Share on other sites More sharing options...
