piper109 Posted July 8, 2011 Share Posted July 8, 2011 Car is 300tdi Disco. Turbo is T28 upgraded by TurboCentre to have a slightly bigger turbine. IP has not been optimized but very slight changes tried by me, otherwise stock. I want to make sure that the turbo is doing the best it can at lower rpm as I have some problems on very steep hills. My driveway is about 200 yards long and is very steep. If I turn into at a good speed in 2nd gear and hold it to 23-2400 rpm, I can sail up the road in second. If I'm a bit slower turning in and the revs drop below about 2100-2000, its all over and I have to change into first gear. I can scream it in first but forget getting it into second. Once it goes off turbo I have black smoke. I have read that the engine produces max torque at 2100 rpm and the turbo comes on at 1800 rpm. I would expect it to lug a bit better at lower rpm than it apparently does. Altitude 3100ft. Am I expecting too much? I am buying a boost gauge to install. What boost should I see at lower rpm? Is it just going to depend on throttle amounts? I know a VNT turbo comes on at lower rpm but I'm not ready to sink a lot of money into as the vehicle is great for what I use it for otherwise. I just want to make sure its adjusted correctly and what I can try to improve it a bit. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 8, 2011 Share Posted July 8, 2011 to be fair that sounds about right for a 300, once they go off boost they are a bit of a 'mare. your not going to see any gains below 1800rpm from turbo mods, as that is where it kicks in, so you're only really going to get improvements from the fuel/air side of things. i would suggest looking at the off boost fuelling (the star wheel in the top of the IP), which may help. IIRC there is a tuning guide in the tech archive, if not, google bosch ve pump tuning to throw up lots of info - or try the turbo diesel owners forum (sorry, can't remember the link) lots of info on there. i don't think you're altitude helps too much either Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 8, 2011 Share Posted July 8, 2011 I understood that if you put a larger turbo on the low rev performance would deteriorate due to the extra mass of the turbine needing more oomph (technical term that). Now that may just affect acceleration, I don't know.... but it may explain why a 2000-2100rpm drive attack just dies and ends sadly.... I'm sure a grown up will be along shortly to explain all Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 8, 2011 Share Posted July 8, 2011 bigger turbo = higher exhaust pressure needed to get going is the diesel pump tuned, try fiddling with that as it can make one hell of a difference and wont affect MPG much at all, in fact i wouldnt surprise if it did more to the gallon as you arent foot to the floor as much. also get a boost guage and see whats what and if you can adjust it Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted July 9, 2011 Share Posted July 9, 2011 This is why I went for a VGT - that and I can't live without the endless hassle of a homebrew project that's never quite finished. I've now got 1 bar boost at 1400rpm and pushing 1.5bar by 2000rpm - it's the first figure that makes the driveability work (though I then went and ruined it with an autobox but it tackles the same issue two ways round). If you're seeing black smoke at full throttle & low revs then you're already overfuelling and you won't get any more performance from the star wheel. First things first - is the air filter clean, pipe runs not pinched or delaminated, intercooler not clogged with old oil etc. Get a boost gauge, make sure the wastegate's pinned shut (use a regulated workshop airline to feed it directly, you shouldn't see any movement until 0.8bar & fully open by 1.2bar, don't stuff 10bar into it accidentally because you'll need to buy a new one). Then, and only then, consider throwing money at turbochargers etc. Quote Link to comment Share on other sites More sharing options...
