tel Posted July 13, 2011 Share Posted July 13, 2011 hi fellas my disco 1 has air con so a normal large intercooler is out the question even tho it would be my main choice, i have an izuzu trooper bonnet vent on my truck so what about fitting the izuzu intercooler to give me some more poke,it has a 2" body lift so i have the extra space needed to fit it i think, pipework i can source no problem am i wasting my time do you recon? wifey wont let me junk the air con either Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 13, 2011 Share Posted July 13, 2011 Is the Isuzu top mount I/C any better than the disco intercooler?? not sure you'd find it an improvement, especially as it would be closer to a hot engine as well. Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 13, 2011 Share Posted July 13, 2011 the full width intercoolers do fit with air con - mine has got one Quote Link to comment Share on other sites More sharing options...
tel Posted July 13, 2011 Author Share Posted July 13, 2011 sorry fellas i forgot to mention i also have a tds goldfish on a first four shadow bumper Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 13, 2011 Share Posted July 13, 2011 ahh that makes a difference. what about an l200 intercooler, they are top mounted, although iirc they aren't much bigger than the standard disco ones, just flatter. alternative would be an uprated standard sized one, bigger area for the same size package. Quote Link to comment Share on other sites More sharing options...
tel Posted July 13, 2011 Author Share Posted July 13, 2011 not thought of an l200 one but what i figured as the izuzu is a 3.1 figured it would be good enough for my weasy 2.5 Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 13, 2011 Share Posted July 13, 2011 l200 is 2.5 as well, and some of the import models are 2.8, failing that, mitshubishi shogun top mount? or imprezza, or lancer, in fact most jap turbo's seem to be top mount i/c. have you investigated propane injection? some big gains to be had there when set up properly. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 13, 2011 Share Posted July 13, 2011 Tel, From personal experience I can tell you that it's nowhere near as good as in the front. The air seems to be thrown above the surface of the bonnet. It was a different motor once the front was rejigged and it was returned to the front. HTH Mo Quote Link to comment Share on other sites More sharing options...
tel Posted July 13, 2011 Author Share Posted July 13, 2011 Hi mo that's all I needed to know thanks very much knew someone would of had to of tried it on here I'll get an updated standard unit Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted July 13, 2011 Share Posted July 13, 2011 I have an Alisport 300Tdi 'cooler designed for the auto Disco so it's the same size as the OE 'cooler but deeper - 50% more 'cooling and fits in the OE hole. Works well Quote Link to comment Share on other sites More sharing options...
ahebron Posted July 16, 2011 Share Posted July 16, 2011 I picked up a Sierra Cosworth I/C for diddly squat that measures nicely to fit between the chassis rails on my D1 300TDi Auto with A/C. Just got to get round to fitting it, though might need to get a bit of pipe work done to make it all work with the factory spec one. Adrian Quote Link to comment Share on other sites More sharing options...
