trulyalya Posted August 3, 2011 Share Posted August 3, 2011 Les, thank you for the post! How do I tell if I have excessive play in the pinion/crownwheel mesh? What type of play is that? My front and rear prop shafts have a clockwise-anticlockwise play of approximately 30°-40° - and I guess that's not nice, but that's the problem of my tranfer box/central diff. The same play in the front/rear diffs is smaller. Is there a simple way of getting rid of it? Where do I find the next pot on rebuilding the diff? (if it exists?) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 4, 2011 Share Posted August 4, 2011 Excessive play you describe is commonly known as backlash, which may be either pinion/crownwheel mesh or driveshaft/drive member wear (or bearings). No tech thread on rebuilding a diff - it's very complicated to do it properly, but you can do an acceptable job by 'feel' Backlash won't cuase the pinion seal to repeatedly fail - poor fitting, worn seal land on the flange, or nose bearing wear are the only things that will cause that. Les. Quote Link to comment Share on other sites More sharing options...
britishnick Posted August 5, 2011 Author Share Posted August 5, 2011 Yep, fair weather mechanic me :-). Probably Friday when I "work from home". I will keep you posted. Cheers Nick Mission accomplished. Hitting it with a centre punch just seemed to drive it into the diff, but the self taper through the metal and pull 'er out worked a treat. New seal in no leaks. Swivel housings greased, speedo cable replaced, air filter changed.....its been a productive day so far. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 5, 2011 Share Posted August 5, 2011 Glad you got it out in the end Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted August 7, 2011 Share Posted August 7, 2011 I love working from home...........LMAO. Quote Link to comment Share on other sites More sharing options...
