Dan88 Posted September 6, 2011 Share Posted September 6, 2011 I need advice again, I'm converting my truck cab to a hard top van style. I need some bolt the fit the sides to the tub, the original land rover ones have a number of washers also included. Can I just use a standard long bolt and some big washers or does it have to be the same style bolt? And does anyone know who can supply these? Thanks Quote Link to comment Share on other sites More sharing options...
landy V8 Posted September 6, 2011 Share Posted September 6, 2011 http://www.lrseries.com/shop/product/listing/17199/2920/2/330762-TRUCK-CAB-MOUNTING-STUD.html these are what you need. they're out of stock here but try other like Britcar or ebay. Quote Link to comment Share on other sites More sharing options...
landy V8 Posted September 6, 2011 Share Posted September 6, 2011 just had a look on Britcar and they're £14 each Ringa around some breakers and ask if you can buy the fixings when they're dismantling a truck.they probably throw them away anyway so it would be worth them sekking them to you. got to be cheaper than new. Quote Link to comment Share on other sites More sharing options...
KKMobile Posted September 6, 2011 Share Posted September 6, 2011 Or big nut & bolt with some heavy duty washers, and use a shock rubber to locate between the 2?? Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 8, 2011 Share Posted September 8, 2011 I did this once as I converted my truck cab to hardtop over Christmas and managed to order everything bar the special round fixings. So it's possible and works, but only issue is that after a while, especially from off roading where you knock the sides and flex the tub, the sides will move. You can undo the bolts, realign and tighten, but it becomes a pain to keep on doing this. So it's better to buy the proper LR fixings everything else is standard M6 & M8 nuts, bolts and washers. Steve Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted September 8, 2011 Share Posted September 8, 2011 Don't forget to advertise your spare truck cab bits on here, should make you back some money after you've bought the unobtanium bolts from LR! Quote Link to comment Share on other sites More sharing options...
Buzza Posted September 8, 2011 Share Posted September 8, 2011 My '95 Defender were these, much cheaper. http://www.lrseries.com/shop/category/search/?search_by_category=&search=mrc9833&submit=Search+the+shop Steve Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 8, 2011 Share Posted September 8, 2011 My '95 Defender were these, much cheaper. http://www.lrseries.com/shop/category/search/?search_by_category=&search=mrc9833&submit=Search+the+shopSteve These are the ones you need, not the ones posted earlier on in the post and as above they are avfewcpounds each, even from an LR dealer. Cheers Steve Quote Link to comment Share on other sites More sharing options...
