reb78 Posted November 19, 2011 Share Posted November 19, 2011 The fuel pump on my eberspacher fills the lines pretty quickly, so i woulnt have thought it would take long to run the fuel up even if it did drain back over a couple of days. I dont know if airlocks are a problem, but i think the angle the pump is set at might be important in that respect. Quote Link to comment Share on other sites More sharing options...
digger 2 Posted November 19, 2011 Share Posted November 19, 2011 just taken seat out and taken a few pics of fuel pump if its any help glad to hear its running ok now. Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 20, 2011 Author Share Posted November 20, 2011 Nice pictures digger. I've just completed the 2 day standing still test and burner and vehicle started just fine so lag, suggesting fuel leak back. I'll keep an eye on it but I think it may be ready for full operational use! hurrah! Mav Quote Link to comment Share on other sites More sharing options...
poohbear Posted November 20, 2011 Share Posted November 20, 2011 Awesome news - now you can just enjoy it! Dave. Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 21, 2011 Author Share Posted November 21, 2011 Mav, A mate of mine has one of these, he has a coupling just before the fuel tank in the filler pipe, as mentioned above. if it's in the normal fuel circuit how do you get it to work in pre-heat mode? I was looking at this the other day as I think I have just found a Thermotop so will be going down this route very soon. Jason. Hey Jason, the burner just works indipendatly from everything else in the engine bay, its just need a 12v supply for a small water pump, fan and fuel pump and a constant diesel supply. I've got mine wired to a telestart system, so I turn it on and off from a key fob, there is also an option to put in a thermostate type control timer too in parallel with the telestart. Like you may follow i was under the impression that the engine could suck fuel out the burner fuel circuit, but that appears to be false. After running it last night I might have to put a silancer on the exhaust, might give a few people a shock if I start starting that up in car parks etc... it is quite loud. Quote Link to comment Share on other sites More sharing options...
