Richy B Posted November 16, 2011 Share Posted November 16, 2011 Hi all, I need to change the rear diff oil seal on a 300 tdi disco, am I right unthinking the flange is tricky to get off ? A puller or special tool maybe required ) done loads on defenders but not disco, many thanks Quote Link to comment Share on other sites More sharing options...
Biffo Posted November 16, 2011 Share Posted November 16, 2011 You've got to pull the centre pin out of the flange first to get at the flange nut, i think (it's along time ago I did mine!) that a long bolt with numerous packing pieces to pull it out, a bit of heat on the flange helps. Once you've got it out, why not fit a flange (& spacer) from a 200TDi along with the propshaft then you've got rid on that bloody doughnut! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 16, 2011 Share Posted November 16, 2011 Slide hammer if you can get hold of one. Thread in the centre of the pin is M8 coarse. Alternatively - use packing washers and a bolt/nut to pull it out. Les. Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted November 28, 2011 Share Posted November 28, 2011 Heat, heat and then a bit more heat before you use the slide hammer, that was my discovery on both occasions when I had to take mine out. On the second occasion I didn't put it back in, I changed to a prop with UJ's both ends. Quote Link to comment Share on other sites More sharing options...
gadget Posted November 30, 2011 Share Posted November 30, 2011 Heat, heat and then a bit more heat before you use the slide hammer ^^^ as above. Quote Link to comment Share on other sites More sharing options...
