Boris113 Posted December 29, 2011 Share Posted December 29, 2011 Morning all. I'm in the process of sanding down the 90's panels to repaint ( not done them for a few years and they aren't looking so great anymore! I have always used oil-based matt nato green before and slapped it on with a brush which looks ok but it holds the dirt and marks badly. This time I went for a roller, I gave a couple of coats of the usual paint with a foam roller to see what it was like and sanded between coats. However I seem to be getting a very bad orange peel texture, am I doing something wrong? It's quite cold in the shed so I've thinned the paint by 10% and applied it in thin layers with over a week to dry between each. I also have a few queries: Are the foam rollers i'm using the right ones or should I use those ones that are more like carpet? Would satin paint give a better finish and apply better? If so is there anything I could mix into the current paint to make it slightly more satiny or should I just buy new paint? I have the option to use a £70 lidl compressor and spray gun, is that likely to give a better job than a roller? Photo attached shows what it looks like a year after brush painting. Many thanks, Harry Quote Link to comment Share on other sites More sharing options...
hobson Posted December 31, 2011 Share Posted December 31, 2011 (edited) Painting in the winter is a nightmare unless you have a heated booth, even thinning the paint it never seems to go on right, really you need to do it somewhere above about 10-15 degrees. Paint is also a sod to dry in the cold, it 'blooms' where it kind of sets but doesn't harden, you'll know it's bloomed as even after a week you can still dig a fingernail into the paint. Satin is easier to work with as it doesn't show up the imperfections as much, i think you can buy matting agent to dull it down but it might be easier to just get another tin. As for rollers, i used the compressed foam ones, don't use the ones that look like wool, they're for emulsion! A spray gun might help, depending on your skill in using it, a good roller job will look a lot better than a bad spray job, but again, it's getting it to dry and harden properly in the temperatures, that's the main problem. Just a thought, but when i paint in the winter, and providing it's a smallish area, i use a red heat lamp we use for the chickens to get it dry, i put it in an old office lamp (the ones with a long adjustable neck) so you can get it into position, you might get away with doing it panel by panel that way,,, Edited December 31, 2011 by hobson Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 1, 2012 Share Posted January 1, 2012 try heating the paint up, I had good results, but again that was in the summer. Brian Quote Link to comment Share on other sites More sharing options...
Boris113 Posted January 1, 2012 Author Share Posted January 1, 2012 Thanks guys! I'm using a double garage but it's pretty drafty, I'll warm the paint and dig out a couple of those oil filled radiators and see if that helps the drying. I'm doing the whole vehicle so can't use a small heat lamp sadly. I've sprayed a few times before and done an ok job but only agricultural machinery whereby finish isn't that important so i'll probably just stick with the rollers. Anybody know a good place to get some satin nato green? Harry Quote Link to comment Share on other sites More sharing options...
wack61 Posted January 1, 2012 Share Posted January 1, 2012 I'd just wait until the weather warms up, you'll only get cheesed off with it doing it over and over Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 1, 2012 Share Posted January 1, 2012 I use paint pads on mine, they seem to leave a better finish than brush. The foam rollers leave lots of bubbles. Quote Link to comment Share on other sites More sharing options...
Smego Posted January 2, 2012 Share Posted January 2, 2012 Good read, I will be doing the same as I have a 5 litre tin of satin nato green but wouldn't attempt it over the winter. Quote Link to comment Share on other sites More sharing options...
hobson Posted January 2, 2012 Share Posted January 2, 2012 I've always used Anchor Supplies, works out about £60.00 including delivery for a 5l satin, there are other places which advertise cheaper, but usually when you add VAT and delivery there's not much in it, do a search and see if there's anywhere close you could pick it up from, it might save you 10-12 quid on delivery. HTH Quote Link to comment Share on other sites More sharing options...
