elbekko Posted January 22, 2012 Share Posted January 22, 2012 Definitely sounds like timing. To be honest, you don't really need the pin in the flywheel, but it does help. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted January 22, 2012 Share Posted January 22, 2012 I'll ask you again How did you check the cam timing ? How did you do the injection pump timing ? Very doubtful if a 30Tdi will do anything other than bent pushrods or broken rockers. The engine is designed for those parts to fail before doing other damage. The 300Tdi engine is very strong and can take a lot of nasty punishment.... in fairness the 300 tdi is a strong engine HOWEVER i have seen bent pushrods, broken rockers and bent valves on this engine depending on the revs when the timing belt went. Quote Link to comment Share on other sites More sharing options...
dm90 Posted January 22, 2012 Author Share Posted January 22, 2012 No i never used a pin on the fly wheel, is that just in the threaded hole in the bottom? everything seemed to line up with out that tho? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 23, 2012 Share Posted January 23, 2012 FIP timing pin position Flywheel timing position - manual gearbox HTSH Chris Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 26, 2012 Share Posted January 26, 2012 Or if you don't want to buy a flywheel timing pin, a wading plug drilled and tapped 6mm with a bolt works, provided you don't put a lot of strain on it ie, don't try to lock the crank to tighten the pulley bolt with it. Quote Link to comment Share on other sites More sharing options...
