davyd8899 Posted January 21, 2012 Share Posted January 21, 2012 just fitted a new cylinder head to my mates 300tdi disco. it runs BUT:- its chucking out white smoke when revved would badly set tappets cause this??? also there was a couple of bolts missing on the exhaust manifold, obviously put a new gasket on however would this cause a lack of back pressure to the turbo to cause the white smoke? it sounds a bit tinny under heavy acceleration too. any advise woulod be greatly recieved dave Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 21, 2012 Share Posted January 21, 2012 Back pressure is a mith.... is it using/mixing its fluids? I'd say to start with its a compression/lack of compression problem causing this... unless you've upset the timing at all. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted January 21, 2012 Author Share Posted January 21, 2012 dont seem to be using/ mixing fluids but only just completed the job today brand new cylinder head, new head gasket new bolts so really shouldnt be a problem there Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted January 21, 2012 Author Share Posted January 21, 2012 oh and timing not been touched Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 21, 2012 Share Posted January 21, 2012 Injector seals in properly, glow plugs in properly. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted January 21, 2012 Author Share Posted January 21, 2012 ahh injector seals in properly........................................................... will check this before anything else, is it possible to buy injector seals seperate?? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 21, 2012 Share Posted January 21, 2012 Yeah I get them from AMD 4 wheel drive.... they cost about 20p each. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 21, 2012 Share Posted January 21, 2012 Does the white smoke smell of diesel, or is it steam? Les. Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted January 21, 2012 Share Posted January 21, 2012 I changed a head and it chucked out white smoke for a little while. The gasket was well and truly knackered with loads of pressure in the cooling system before I swapped the head out, so I presume there was water all over the place. The smoke cleared after about 10 mins and all was OK. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted January 21, 2012 Author Share Posted January 21, 2012 its not steam. certain of that. pretty sure its as vulcan bomber said its the injector seals as they were pretty ropey when i put them in. I changed a head and it chucked out white smoke for a little while. The gasket was well and truly knackered with loads of pressure in the cooling system before I swapped the head out, so I presume there was water all over the place. The smoke cleared after about 10 mins and all was OK. must admit tho. after 10 minutes of it running the smoke did clear a bit. hes gonna run it for the week and see if it clears. Quote Link to comment Share on other sites More sharing options...
