insulating ceiling tiles?
integerspin
I was wondeing if anyone isntalled them.
I just made an extension for my garage oven, to powder coat some long parts
not to heat long sausage rolls;-)
I don't want to use rockwool/fibreglass as it will be dusty[won't it], the oven blows air
thru the front and will possibly blow dust everywhere. I was going to use PIR
board, eventually got a mail from Celotex telling me it defineitely wasn't any good for
200ºC. I am sure there must be ceiling tiles that insulate and if they are fireproof
they will be OK for half hour[at most] at 200ºC. I asked in a builders merchant's they
weren't to helpfull.
Most annoying thing is I extended the oven 14.5", a pair of rocker covers
and a pair of girder forks I need to coat fit. I just found a couple of items that could
do with coating, they are a few inches to long to go in the extended oven.
Not sure if this is correct, but there is a tile backing board on the market that is made of a cementious product which i presume is heat resistant to high temperatures, very similar to the asbestolux material used as a soffit on roofs but thicker. 1200x900 sheets if my memory serves at about a tenner or so a sheet, think they sell it in B&Q.
Hope this is of some help.
Cheers
Charlie
Rockwool, with a Stainless steel sheet on the oven side...
Its what we used to use in 300 degree ovens.
That's what i was trying to avoid. There is a fan in the top of the oven, it blows
the hot air from inside the case out the front. So the fan will be blowing over the
top of the extension, if it's double skinned and rockwool filled, the rockwool is
going to have to be sealed in to prevent dust.
Still I have enough ali left to doubel skin it, so it likely thats what I will end up doing.
The double skin will also have to come off to remove the extension, the bolts
holing it to the oven are located round the edge.
I should'nt have been such a skinflint, I should have paid someone to coat the
bits[no couldn't be doing that], or wet painted them.
I shoudl have built an oven from scratch;-)
Or not thrown away the old sterilising oven from the hospital I used for carbon.
