deanlr90 Posted February 5, 2012 Share Posted February 5, 2012 Hi,My defender has a diahatsu engine and recently the glow plugs needed replacing,been fitted for 6 years,just routine maintenance.I quoted the ref no. off the old plugs and bought ngk they looked the same.Fitted and everything was fine for 3 days,now they have stopped working.I took them out and tried them out tested them on an old battery...nothing.The only thing I can think is either there duds or because they are wired direct to the ignition,this has damaged them,but as this system has in the past worked I'm sceptical about that.Any ideas? Quote Link to comment Share on other sites More sharing options...
DagdaNI Posted February 5, 2012 Share Posted February 5, 2012 when you say wired to ignition do you mean wired that when ignition on there on so always on when driving ? that would burn them out need to be on a timed relay or wired that they go off when she starts, generally glow plugs are pretty simple live and earth and they heat up, are you sure they have failed ? if they have failed that quick must be duds or getting burnt out by being on to long Quote Link to comment Share on other sites More sharing options...
deanlr90 Posted February 5, 2012 Author Share Posted February 5, 2012 They go off when the engine starts,you have to hold the key to activate them.I have had the last set in for 6 years so expected them to work fine.I tried a continuaty test which showed nothing,so connected them to a battery just to make sure still nothing.It must be a problem with the plugs just seems odd all 4 stopped working after only 3 days.The only thing I have done that could have made a difference is add a twin battery system to run the winch but I'm not getting any problems with anything else and that was a couple of months ago. Quote Link to comment Share on other sites More sharing options...
22inch roller Posted February 5, 2012 Share Posted February 5, 2012 I've had the same problem I have to slightly hold my ignition key on to get um to work im in the proceed of wiring up a manuel live with relay and switch Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 8, 2012 Share Posted February 8, 2012 Just a quicky on the glow plug subject....I've just removed mine (and all in 1 peice).....Checked them for working and all 4 good! But one of the glow plugs was black with soot form tip to threads...other 3 pretty clean really, any ideas as to why this has happened on one, anything to worry about, can it be sorted? Cheers Mutley Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 Really just a guess Mutley but is there a chance the injector on that cylinder is over fueling or generally not functioning correctly? Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 8, 2012 Share Posted February 8, 2012 How do i check?find out? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 How do i check?find out? You'd need to take the injectors to a specialist to check them, but I'd wait for an adult to come along with an opinion before forking out money based on my guess. Quote Link to comment Share on other sites More sharing options...
