barriesheene Posted March 14, 2012 Share Posted March 14, 2012 Anybody on here know how to get one shot swivel grease INTO the swivel housing and not all over the OUTSIDE of the swivel housing Good job I bought lots Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 14, 2012 Share Posted March 14, 2012 Turn the steering full lock helps, as does making sure the one shot is warm. Quote Link to comment Share on other sites More sharing options...
barriesheene Posted March 14, 2012 Author Share Posted March 14, 2012 I did think that but it was on a bottle jack so thought better of it Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 14, 2012 Share Posted March 14, 2012 Use oil if your swivels have the drain as well as the fill holes Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 14, 2012 Share Posted March 14, 2012 Oh, and if your truck has ABS, its a whole lot easier filling through the ABS sensor hole Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 15, 2012 Share Posted March 15, 2012 Is the grease coming back out of the hole as you try to squeeze it in? If so, then full lock so that you are putting it into the cavity behind the cv, and remove one of the top swivel pin bolts so that air can escape as the grease goes in. Les. Quote Link to comment Share on other sites More sharing options...
barriesheene Posted March 15, 2012 Author Share Posted March 15, 2012 Is the grease coming back out of the hole as you try to squeeze it in? If so, then full lock so that you are putting it into the cavity behind the cv, and remove one of the top swivel pin bolts so that air can escape as the grease goes in. Les. Top tip. Cheers Les Quote Link to comment Share on other sites More sharing options...
