mcc1979ian Posted May 28, 2012 Share Posted May 28, 2012 hi, iv been rebuilding the 90 and finally bout ten tonight i got round to fitting the driver side wing but the inner wing sat tight against my tubular turret causing the wing to sit wrong so iv removed the turret for now and the wing now sits perfect, the question is does anyone know a solution around this as i dont want to fiddle with the turret, the only other thought i had was a pair of turrets i found on ebaywhich arent tubular but just have two uprights front and back so surely this wouldnt interfere with the wing, anyone used these and if so are they any good? Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted May 29, 2012 Share Posted May 29, 2012 They should be just fine! Gwyn Lewis gear is very good equipment and plenty of people use his products. Its well made, durable kit, money well spent! Quote Link to comment Share on other sites More sharing options...
chadler Posted May 29, 2012 Share Posted May 29, 2012 Try the other turret, If I recall correctly then they are slightly 'handed'. I think you'll find if you try both that one will fit and clear the wing. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 29, 2012 Share Posted May 29, 2012 They are indeed handed, look here: http://www.gwynlewis4x4.co.uk/page51.html Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 29, 2012 Author Share Posted May 29, 2012 aye i notice the glyn lewis ones are handed but did you mean the tubulars are handed aswell? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 29, 2012 Share Posted May 29, 2012 Difficult to say without the make, any ideas? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 29, 2012 Share Posted May 29, 2012 Gywn lewis stuff is great, its what I have on my 90 . Don't know about the other ones, but Gwyns are definitely handed. One thing, are the turrets extended height-wise? if so then you will need to remove the plastic covers. That could be what is making the wings sit funny. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 29, 2012 Author Share Posted May 29, 2012 standard height terrafirma turrets Quote Link to comment Share on other sites More sharing options...
