eastw77 Posted June 20, 2012 Share Posted June 20, 2012 Hi, Would the drive shafts from a Disco 1 be compatible with a Range Rover Classic? thanks. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 20, 2012 Share Posted June 20, 2012 By drive shaft do you mean half shaft? I'm not sure they are. My friends hybrid had rangy classic axles under it with 10-spline diffs. We upgraded it to 24-spline diffs from his disco 1, but we had to use all the hubs and stub shafts and half shafts from the disco one - the rangy stuff just wouldn't fit. Quote Link to comment Share on other sites More sharing options...
eastw77 Posted June 20, 2012 Author Share Posted June 20, 2012 Sorry, I meant prop shafts not drive shafts.. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 20, 2012 Share Posted June 20, 2012 Rear yes, front maybe, if ithe RRC has the Borg Warner transfer box, the front prop will be too long, from 1989 on that was, if it has the LT230 then it will be fine. Quote Link to comment Share on other sites More sharing options...
eastw77 Posted June 20, 2012 Author Share Posted June 20, 2012 I have an LT230 so I will be ok. Thanks! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 23, 2012 Share Posted June 23, 2012 Rear - maybe - does the disco have a rubber doughnut ? If so, it is no good. Quote Link to comment Share on other sites More sharing options...
eastw77 Posted June 24, 2012 Author Share Posted June 24, 2012 Why is that? If the length is OK will it still not work? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 24, 2012 Share Posted June 24, 2012 Good point, 3 bolts rather than 4 -easy to tell! Unless you are swapping the axles from the Disco as well, in which case no problem. Quote Link to comment Share on other sites More sharing options...
eastw77 Posted June 24, 2012 Author Share Posted June 24, 2012 Right, thanks guys. I'll have to find out if it has a donut.. Quote Link to comment Share on other sites More sharing options...
