CJB Posted July 23, 2012 Share Posted July 23, 2012 Has anyone put a 90 rear axle on a 110. The Sailsbury needs a spreader so its easier to put a locker in a 90 axle. I prefer 110 because it does not pitch and make me seasick!! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 23, 2012 Share Posted July 23, 2012 Salisbury axles we're fitted to 110's for a reason. That being the standard rover axle isnt rated for the max payload of a 110. If your that fussed then the later td5 onwards have a different rear axle with a different diff, that camr from the P38. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 23, 2012 Share Posted July 23, 2012 The Salisbury / 110 story is a bit strange. It was originally fitted to the 109 which was mostly used in 2wd so needed a strong back axle. And the same axle was carried over to the 4wd Defender. It is a very strong diff so worth keeping. Quote Link to comment Share on other sites More sharing options...
CJB Posted July 23, 2012 Author Share Posted July 23, 2012 Fair enough - its just that I got the impression it's very difficult to put a locker or LSD in a Sailsbury. Cause what I want is a 110 with a quaife torsen in front and back. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 23, 2012 Share Posted July 23, 2012 Personally i dont think the salisbury diff is as scary as people make out. Quote Link to comment Share on other sites More sharing options...
kiwi_110 Posted July 24, 2012 Share Posted July 24, 2012 I've managed to install ARB lockers into 2 different 110's salisbury diffs without needing to distort their cases. If it is necessary, it can be done with a cargo strop around the axle tube and centre x-member tensioned up. Ray. Quote Link to comment Share on other sites More sharing options...
simonr Posted July 24, 2012 Share Posted July 24, 2012 I've managed to install ARB lockers into 2 different 110's salisbury diffs without needing to distort their cases. If it is necessary, it can be done with a cargo strop around the axle tube and centre x-member tensioned up. I agree - it's very easy, if you need to do it at all. Ratchet strap or winch are easiest. Most older Sallisbury's (and they are all fairly old now) are worn enough that the diff just falls out! Si Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted July 25, 2012 Share Posted July 25, 2012 Before you spend money upgrading a Salisbury axle – whether it’s lockers or a disc-brake conversion – make sure you cost everything up carefully, it soon mounts up! It may well be cheaper to find a later standardised axle and add toys to that, which will give you disc brakes into the bargain. E.g. http://www.ebay.co.uk/itm/Landrover-Defender-110-Rear-Axle-2006-/320951618883?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aba350d43 Quote Link to comment Share on other sites More sharing options...
CJB Posted July 26, 2012 Author Share Posted July 26, 2012 Ok all. Thanks for your replies. I'm not going to let sailsburys put me off! Quote Link to comment Share on other sites More sharing options...
