CwazyWabbit Posted September 2, 2012 Share Posted September 2, 2012 Is this the one? http://www.hydraulicpartsdirect.co.uk/ford-7810791082108610-power-steering-pump-gpe6nn3k513ta-p-39.html Is it bigger due to a self contained reservoir? I can't tell from the description, 'tank type' could mean it has a tank or needs one! Quote Link to comment Share on other sites More sharing options...
mikec Posted September 2, 2012 Share Posted September 2, 2012 Found the specs for my pump. Max pressure is 3625 psi, max speed 3500rpm giving max flow of 29.7 lpm, min speed is 500 rpm giving min flow of 4.03 Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted September 2, 2012 Author Share Posted September 2, 2012 Yes that's the one, yes the reservoir is built in like some of the RangeRover ones, but it is still huge by comparison. It's gear driven off the camshaft drive. I know after bursting a hose that despite the large looking tank it doesn't hold that much, and when empty you can see through the filler that the pump runs the full length of the tank. Quote Link to comment Share on other sites More sharing options...
