stobbie Posted October 1, 2012 Share Posted October 1, 2012 I'm converting a EDC 300TDI to non-EDC I can buy a 300TDI injection pump, but it has no sprocket and it has not been locked at TDC. Can I just turn it to TDC, fit a locking pin and attach the sprocket of the EDC pump? Or is it less easy than that? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 1, 2012 Share Posted October 1, 2012 asuming the pully's are the same, yes. Locking pumps before removal is a myth. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted October 1, 2012 Share Posted October 1, 2012 Erm, are you doing three of them?! Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted October 1, 2012 Share Posted October 1, 2012 how do you intend to time the pump sprocket up to the internals of the pump as there is no keyway? the sprocket is also how you lock it to TDC aswell, normally you have to get an injection pump specialist to refit the sprocket & time it up through the back of the pump casing using a dti etc not the easiest of jobs Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 1, 2012 Share Posted October 1, 2012 The sprocket or pully is fitted to the hub through slotted bolt holes.. its ok not to time it. Remove the hub and you have to retime the pump with a DTI. Quote Link to comment Share on other sites More sharing options...
stobbie Posted October 2, 2012 Author Share Posted October 2, 2012 How can I tell if the hub has been off? The 22mm nut is on, but the seller did not take it of the engine himself. Is someone does not know how to remove the pump from the engine he may have been temped to undo the 22mm nut.. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted October 2, 2012 Share Posted October 2, 2012 Sorry I mis worded my post, I was refering to the hub as described by vb Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 2, 2012 Share Posted October 2, 2012 Sorry I mis worded my post, I was refering to the hub as described by vb No worries, cant be helped if we're singing off different hym sheets.. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 2, 2012 Share Posted October 2, 2012 How can I tell if the hub has been off? The 22mm nut is on, but the seller did not take it of the engine himself. Is someone does not know how to remove the pump from the engine he may have been temped to undo the 22mm nut.. Bung the pump on the engine and run it before you reassemble the timing casing. If its out it wont run and we can set about sorting it then. Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted October 2, 2012 Share Posted October 2, 2012 there is away of locking the pump , there is a bolt directly underneath the pump, loosen the bolt off, remove the shim, and tighten, assuming it is in tdc. I suppose you could totally remove and turn the pump until you see the locking point. Brian Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 2, 2012 Share Posted October 2, 2012 there is away of locking the pump , there is a bolt directly underneath the pump, loosen the bolt off, remove the shim, and tighten, assuming it is in tdc. I suppose you could totally remove and turn the pump until you see the locking point. Brian Theres no TDC point in the pump. You can only set them by measuring the rotation point and length on the delivery piston. Quote Link to comment Share on other sites More sharing options...
