14Platoon Posted September 15, 2018 Share Posted September 15, 2018 Did you ever sort this? I have the same job to do! Quote Link to comment Share on other sites More sharing options...
Kurt Posted September 16, 2018 Share Posted September 16, 2018 Rebuilding mine at the moment and my frame to bulkhead has a bit of a gap but only at the ends? I might have to pack a bit of butyl in there. I used roof and gutter sealant on my roof to frame after fitting a new seal. Quote Link to comment Share on other sites More sharing options...
Wheely Posted January 5, 2019 Share Posted January 5, 2019 On 7/8/2018 at 1:04 PM, Wheely said: Hey guys! As I am rebuilding Wheely following a complete respray I put the seals between roof and bulk head/windscreen frame (as per pic) BUT: when I tight the roof completely with the nuts and bolts there is still a big gap between windscreen frame and roof (see pic) the seal between bulkhead and windscreen frame is rather loose What could be the reason for that? This is the last hurdle before the Landy is completely rebuild and can finally take it for a ride :):):) thanks for your support! Hey guys, been travelling so couldn't finish this up - to recap (pics in previous post): the LR055345 one in foam is genuine LR, the MTC4994 in soft rubber and MTC6568 in foam are britpart - it just looks like there is not enough pressure on these foam seals (the plastic one can't be seen as it's between roof and windscreen) - also the MTC6568 is not long enough to cover the full roof width... Was thinking that the easiest solution would be just to replace the MTC6568 and LR055345 with alternative seals neoprene slightly thicker and for the MTC6568 also to cover the full lenght of the roof from end to end What are your thoughts on it? thanks for your support! Simone Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 13, 2019 Share Posted January 13, 2019 With regards to the original post, I used the Land Rover seals and then sealed over with Tiger seal, the genuine seals left gaps. I did the same with the window panel seal too. Quote Link to comment Share on other sites More sharing options...
