defender roof lining/ floor carpet
I have recentlly insulated and retrimmed the roof and rear of my 110 hardtop. Still got to do the front though.
After stripping it out and cleaning I applied flashing tape to roof, sides, wheel boxes and floors. Followed by 25mm Kingspan on roof and side panels. All areas not covered I used Wickes bitumen waterproofing stuff, cause I had some already n thought it'd cut down condensation.
Insulated it all then used 3mm ply for sides n wheel boxes covered in Veltrim vehicle carpet.
2mm mdf for the roof covered in a faux leather from Dunelm Mills and used 3mm chequer plate rubber matting for floor n 2mm chequer plate rubber matting for seatbox and footwells.
Got the ply from local timber merchants.
Kingspan from builders yard.
Veltrim, chequer plate rubber matting, Mdf sheets n adhesive spray came from Harrison Trim Supplies .co.uk. On eBay too as "toeragstruckmats".
Pretty impressed so far, it's definitely warmer, cured the condensation but I am
hoping the bulk of the noise will decrease when I finish cab area n seatbox.
Hope this helps.
Chris
Ha
See your point for defo.
When I got it the previous owner had fitted the back out in 12mm ply and a hand made drawer between the wheel boxes, floor to roof cupboards on top of wheel boxes. Plus a few other bits n bobs.
I was getting 19 to 20mpg so decided to weigh it at work. 2900kgs!!!
Took all that out plus water tank roof rack and spare wheel carrier n it came down to 2200kg.
Mpg shot up to about 25.
But it was a lot noisier so I plumped for a compromise.
Still have enough issues to remind me it's a Land Rover!
Love it though!
