des90 Posted November 15, 2012 Share Posted November 15, 2012 Does anybody know if a transfer box off a 1987 defender,with a lt77 box, will fit straight on a r380 circa 1999 out of a disco Quote Link to comment Share on other sites More sharing options...
jbs Posted November 15, 2012 Share Posted November 15, 2012 Yes they will, BUT they're different ratio's, "Anorak on" The 90/110 box is 1:410 ratio, where as the Disco box is 1:222 ratio "Anorak off" a lot of people go the other way round as they want longer legs for better fuel economy HTH John Quote Link to comment Share on other sites More sharing options...
ashtrans Posted November 15, 2012 Share Posted November 15, 2012 sorry to 'out anorak' you ! but if it's a 1999 it will be a 1.211 ratio and you can only fit the 1.410 if you also change the front prop flange, hi/lo lever and plug the speedo drive, you will also not be able to fit the low range switch in the front housing as it's not drilled and tapped on the 1.410 Dave Quote Link to comment Share on other sites More sharing options...
jbs Posted November 15, 2012 Share Posted November 15, 2012 sorry to 'out anorak' you ! but if it's a 1999 it will be a 1.211 ratio and you can only fit the 1.410 if you also change the front prop flange, hi/lo lever and plug the speedo drive, you will also not be able to fit the low range switch in the front housing as it's not drilled and tapped on the 1.410 Dave Many apologies Dave, and thank you for correcting me John Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted November 15, 2012 Share Posted November 15, 2012 Dave is the ultimate Land Rover drive train anorak Quote Link to comment Share on other sites More sharing options...
