TheRecklessEngineer Posted November 18, 2012 Share Posted November 18, 2012 So what you need is a physical dash gauge driven by the sensors connected to MS. Sounds like a new product in the making Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 18, 2012 Share Posted November 18, 2012 Work out what thread the existing sender in the head is and replace this with one to suit whatever gauge you buy. VDO do a good range of senders in a very wide variety of threads. You do not want the sender in the top hose, you want it in the head. If for example your thermostat fails shut, with the sender in the top hose, you gaueg will read stone cold whilst in actual fact the engine is massively overheating. With the sender in the head it tells you the true engine temp. Egauges.com are usually the cheapest even with shipping and delivery is also usually quicker than from uk based suppliers. Jon Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 20, 2012 Author Share Posted November 20, 2012 Sorted Was looking (and Gul[ping) at the SPA unit, when I was chatting to a mate he said "Ah got something you might use..." http://www.demon-tweeks.co.uk/motorsport/gauges-auxiliary/stack-pro-control-water-temperature-gauge Brand new in box - mssing sensor Sensor ordered and will have a all singing dancing jobbie ....for not much more than a damned good take way for 2 Actually it was a Takeaway for 2, plus a bottle of Scotch Thanks for all the input, ...somehow this is going in the manifold, ....even if the damned thing has to come apart again Nige Quote Link to comment Share on other sites More sharing options...
zim Posted November 20, 2012 Share Posted November 20, 2012 You'll like the stack gauge. Until you drive at night Best get some sunglasses. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 20, 2012 Share Posted November 20, 2012 You jammy bugger. Good gauge that. Quote Link to comment Share on other sites More sharing options...
