TF871 - Bulkhead Removal Bar Installation
ajh
Has anyone installed one of these TF871 bulkhead removal bars? They did not come with instructions and a couple photographs would be very helpful right now as I'm really not sure where to start and I only unpacked it just now to discover the total lack of any directions, diagrams or anything other than the steel bits, the function of which I can guess but the way they fit together seems to be non-obvious.
Ive never liked the idea of removing the rear bulkhead. The main bulkhead and rear bulkhead provide the only real side-impact protection for front seat occupants. Yes removing it gives more room for taller drivers but at what cost?
Each to their own mind you
no bulkhead in a 110 station wagon, so removing the upper part won't make any difference.plus 90/11- sit higher than bog standard euroboxes, so side impact not affected.
Guest wunntenn
I fitted the MUDSTUFF one and it is well made and robust. Wasn't a terribly hard job but make sure you have several blades for your jigsaw and a decent pair of ear defenders and a mask as without them you'll be deaf and coughing.
